Using TS 3.0.10 with a TinyIOx expansion board to enable 9 additional ADC inputs. 8 of the 9 CAN ADC inputs read fine in TS but one does not (generic sensor 3; CAN ADC03). It reads correctly in the "Realtime Display" of the TinyIOx part of the project but does not read in the "Realtime Display" part of parent MS3-Pro project.
Since the TinyIOx appears to be reading the ADC correctly, is there some setting or configuration incorrect that is not allowing TS to poll the data properly?
Any ideas of what to check?
Project archive and screen shots attached. Had to strip out the non essentials from the archive to upload. If anything important is missing let me know.
TinyIOx Realtime Display showing ADC3
Main MS3-Pro Realtime Display showing generic sensor3
CAN ADC03 channel (sensor3) not reading in TS
MS3-Pro 1st Gen | Honda K24 Supercharged
MS3/MS3X | SB Ford 347 stroker
Re: CAN ADC channel not reading in TS
As far as I can tell, your settings are fine. I wonder if the alpha code you're using has some debug left overs as James some times uses the generic sensors as temporary debug information. You may need to post that in the MS3 development section. This likely has nothing to do with TunerStudio.
This is definitely a firmware issue. I loaded the stable 1.4.1 and all the CAN ADC channels read fine.
I added the dashboard files so you can load the previous project if needed.
Re: CAN ADC03 channel (sensor3) not reading in TS
As Jean guessed, this was remnant debug code. It will be ok for the next alpha.
