Hello,
i've discovered following problem:
When i enable the PP2Idle my PP3-Boost output gets always active.
More Background:
I use the PP3 Boost for a green LED, which is active for gear = 0 (Neutral)
The PP2-Idle is orange LED, which is active when rpm >12.000
When i set only the green LED alone (Boost) there is no problem and everything is working like it should.
But when i hit the checkbox to enable the PP2-Idle output setting my PP3 (green LED) is burning, no matter the PP3 setting there.
Its not a connection problem, as the green light does not burn, when the PP3 output is deactivated. (And pp2 conditions are not met)
Its the MS3 1.4.0 Source Code.
Turning the MS on and off doesnt help.
Bug at programmable Outputs
Re: Bug at programmable Outputs
I've investigated and confirmed that something strange is going on.
This is a very old bug in the way "=" is handled. As a workaround use "< 1" instead of "= 0". It will be resolved in the next releases.
okay thanks, i will try it and report.
Edit: its working.
Edit: its working.
