Would like to be able to control water spray for the intercooler.
Arming could be RPM, MAP, IAT
It will need an on time and off time, if you need more info please let me know
Feature Request - Intercooler spray bar
Re: Feature Request - Intercooler spray bar
you can do a kind of thing with general output and loops... but it might be a little complicated depending on exactly what you want to do...
want to get an output to turn on is rpm > 2500 & MAP > 130 & IAT >50 for 2 seconds, then off for say 4 second.
There are no timer features in the on/off outputs (yet?) so that isn't immediately possible without writing some code.
Could you use a 555 timer to hold a relay closed for an extra 2 seconds? Then just use the standard programmable outputs.
