With new method for active CL idle (only RPMdot), in some engines, is difficult stabilize the idle speed.
I Prefer "RPM min" for enble or disable CL idle. Is possible insert the selection for method?
Regard
Cristian
CL idle status
Re: CL idle status
On MS3 we switched to engine states in 1.5 which negates the need for most of the activation settings and works quite a bit better.
Re: CL idle status
Hi Ken,
thanks for repaly.
I have tried alpha 1,5, but for me (my opinion), the system is difficult. The engine "race" with lightweight flywheel, RPMdot have fast fluctuates.
If I use large value RPMdot for enable CDidle, pid is activated too early and PWMdutyIdle decrese value and the engine shutoff.
The other guys are fine with the new system?
Best Regards
Cristian
thanks for repaly.
Best Regards
Cristian
Re: CL idle status
Yes. I have had nothing but good feedback on it. Mainly because idle is locked out based on more than just RPMdot.
Re: CL idle status
Thanks Ken,
I will try to better understand the new method.
Best Regards
Cristian
Best Regards
Cristian
