To announce the release of "MS3 Pre 1.4.2 beta 2"
Who should use this code?
Users requiring the bug-fixes.
Who should not use this code?
New or casual users – please use the current release code instead – see the Downloads page linked above.
Main changes since the pre-1.4.2 beta 1 firmware
Bug fixes:
Fix '=' condition in on/off outputs (ancient bug)
Revised sync method for signature PIP TFI.
MAP logger was sending two zeros at end of data.
New / changed features:
Minor / internal:
The firmware zip is available from:
http://www.msextra.com/downloads/dev/ms3/1-4-2/beta-2/
Be sure to read the README.txt and RELEASE-NOTES.txt that are supplied in the zipfile.
Upgrading users are advised to enable the "old baro calc" for backwards compatability.
Some of the ini changes will result in harmless warnings when loading MSQs from 1.4.x
Users upgrading from 1.2.x or earlier codes need to pay more attention.
TunerStudio 2.6.x or later is REQUIRED.
Go ahead and use the built-in firmware loader on the Tools menu of TunerStudio 3.0.x - you'll like it.
MS3 pre-1.4.2 beta 2 released
