To announce the release of "MS3 Pre 1.4.2 beta 3"
Who should use this code?
Users requiring the bug-fixes.
Who should not use this code?
New or casual users – please use the current release code instead – see the Downloads page linked above.
Main changes since the pre-1.4.2 beta 2 firmware
Bug fixes:
Only check config errors at boot to reduce chance of lockup when loading a defective MSQ.
SDcard FAT32 erase tweak.
Lambda target now respects stoich value. (Ancient issue.)
New / changed features:
Minor / internal:
The firmware zip is available from:
http://www.msextra.com/downloads/dev/ms3/1-4-2/beta-3/
Upgrading users are advised to enable the "old baro calc" for backwards compatability.
Some of the ini changes will result in harmless warnings when loading MSQs from 1.4.x
Users upgrading from 1.2.x or earlier codes need to pay more attention.
TunerStudio 2.6.x or later is REQUIRED.
Go ahead and use the built-in firmware loader on the Tools menu of TunerStudio 3.0.x - you'll like it.
MS3 pre-1.4.2 beta 3 released
