MS3 pre-1.5 alpha 8 released
To announce the release of "MS3 pre-1.5 alpha 8" this supercedes "MS3 pre-1.5 alpha 7".
Who should use this code?
Experienced users wanting to test the new features.
Who should not use this code?
New or casual users – please use the current release code instead – see the Downloads page linked above.
Main changes since pre-1.5 alpha 7 firmware
Bug fixes:
Fixed bug when boost dome control was enabled interfering with injector outputs.
Remove debug code from alternator.
MAF: Change bitmasks to fix setting problem.
MAP: Change bitmasks to fix setting problem.
Handle 3-cyl 2-stroke with COP.
Boost vs. speed, correct curve for dome.
New / changed features:
Remove 'new' noise filter.
Expose "Internal MAP sensor" as analogue in option on MS3-Pro-ult.
Minor / internal:
ini tooltip tweak
Standardise capitalisation on "Analog In x" names.
The firmware zip is available from:
http://www.msextra.com/downloads/dev/ms3/1-5/alpha-8/
Be sure to read the README.txt and RELEASE-NOTES.txt that are supplied in the zipfile.
Upgrading users are advised to enable the "old baro calc" for backwards compatability.
Some of the ini changes will result in harmless warnings when loading MSQs from 1.4.x
Users upgrading from 1.2.x or earlier codes need to pay more attention.
TunerStudio 3.0.x or later is REQUIRED.
Go ahead and use the built-in firmware loader on the Tools menu of TunerStudio 3.0.x - you'll like it.
Boost dome control supplement manual
http://www.msextra.com/doc/pdf/Boost-supplement-1.5.pdf
Bug fixes:
Minor / internal:
ini tooltip tweak
Re: MS3 pre-1.5 alpha 8 released
Note, we are now in a "feature freeze" phase with the new MS3-Pro Ultimate due soon.
Please do test this firmware if you can and report anything that does not work as expected.
Also, DIYAutoTune is offering store credit to the first 30 people to test this firmware and report back in the next 3 weeks:
https://www.diyautotune.com/betatesters/
Installed last night. There is no CAN EGO option under the afr/ego options page. There are 2 EGO option though.
CAN EGO is an option for v1.5 a4, but is missing in a5. (just checked)chips60bug wrote:Installed last night. There is no CAN EGO option under the afr/ego options page. There are 2 EGO option though.
Thanks. I will correct that for the next release. EDIT: If you are able to test a intermediate code, please send me a PM.chips60bug wrote:Installed last night. There is no CAN EGO option under the afr/ego options page. There are 2 EGO option though.
Feedback. Closed loop boost isn't working. Boost works in open loop, but not closed loop. Back ported to 1.5.4 and closed loop boost works again
I have logs and can post later is needed
Here is logs and tunes. Ill put descriptions with each
and the datalogs
Thanks for the tunes and logs. There was a one line typo to blame. Looks back to normal on the bench.nathaninwa wrote:Feedback. Closed loop boost isn't working.
The fix will be out soon.
Closed loop target boost table blending by flex% still isn't working.
Flex% is reading 80%, but it's using the unleaded target table.
[edit]
Oh, I should have read the above first
James, if you have a quick build you want tested, ill give it a go.
[edit]
Toyota Celica GT4/Alltrac with 5S-GTE stroker (2.2L I4 turbo, high CR) on E85 w/FlexFuel.
MS3 + MS3X + KnockBoard + RTC + BT + DIY CAN-IO-Board + DIY CAN Digital Dash.
I wasn't aware of a reported issue, but I just tested what I believe to be the scenario on the bench and it seems to be working now.MWPau wrote:Closed loop target boost table blending by flex% still isn't working.
