Feature Request: "Toggle" Datalog
Not sure if this is possible, or simple. But would it be possible to use a switch input for logging, instead of a momentary button?
Turn switch on: Datalog starts
Turn switch off: Datalog starts
Would make it possible to not need an LED for knowing when you are logging. And easier to just flip it on if you need to try and catch something going on.
Re: Feature Request: "Toggle" Datalog
You can already. If you go to "Data logging" -> "Triggered Logging", you can setup parameters with which to start and stop logging based on a hardware switch, internal data, or an expression.
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
Personal Vehicle:
And that will log to the SD card?
I also can't find the "Datalog" input in the trigger list.
Yup, interal datalog to the SD card.
The hardware switches are based on the port statuses.
Personal Vehicle:
Personal Vehicle:
Nope, automatic triggered logging is only for TS datalogging, not for the SD card datalogging. I still like your idea, as the toggle switch also acts as a visual indicator that you have actually enabled logging, without having to use an output for a LED (Yes, I understand that the LED will also tell you that the ECU is actually logging, ie you haven't forgot to insert an SD card!).aidandj wrote:And that will log to the SD card?
The man behind MS Labs
Yeah... I clearly had a brainfart there.
Datalogging -> SD Card Datalogging
Personal Vehicle:
Personal Vehicle:
It almost works btw. Flip it on and the datalog starts. And you can keep it on. But to turn it off you have to toggle the switch off, then on again, then off.
If James or Ken could weigh in on this and whether its a possibility that would be awesome.
Otherwise I'm going to go rewire my junk.
My car is a street car, and always having the datalog flashing can be really annoying, especially at night. But without the datalog output I don't have a way of knowing its logging or not (because of the button pushes required), with a toggle switch you always know if its logging or not (unless there is an error)
No, it's not possible presently.
Ok thanks. I will rewire. Should have read the manual first.
Any chance of an option to change the light output? To on when logging, and off when not logging?
Or I guess even a way to invert the LED output. Flashing when logging, off when read? I could probably do that with hardware.
Ended up solving the problem a round about way.
https://www.youtube.com/watch?v=ol8Bn4oq47c
Send the sd card status to my iq3s. Turn on warning light when sd card status is logging.
Problem solved.
Problem solved.
You can use a programmable output instead if you don't want the blinking LED. Test for SD_status & 8.aidandj wrote:Any chance of an option to change the light output? To on when logging, and off when not logging?
