hi
James I notice that in the vvt s54 settings if I configure nitrous1/2 as main output for the solenoids (20 hz frequency) and I use injbank1/2 with 99 hz frequency for idle I get configuration error saying that the frequency must match for nitrious/injbank outputs, but if I configure nitrous1/2 as and output 2 for the solenoids and still use the injbank1/2 for idle with the 99 hz frequency the error message does not shows.
Should it give the same warning in both cases? or i should not give the warning at all I am not sure I know that some banks share the frequencies but if I remember correctly if the frequency is slow it can use different frequencies.
Ms3 1.5 code strange config error
Re: Ms3 1.5 code strange config error
The error sounds correct.
The secondary VVT outputs are controlled with software PWM and operate independently. The primary VVT outputs use hardware PWM and are subject to the hardware design of the processor chip which groups channels together.
