Add CLT, MAT as parameter for Blend Curves
Reverant
Post by Reverant »
As the title says, I would like to be able to blend VE, ignition and AFR tables based on CLT or MAT. For example, with table blending on VE and AFR tables based on coolant, I can add more fuel at idle and lower revs when the car is cold, without bucking due to too much fuel at mid/high load. By blending the ignition tables based on MAT, I can add more timing only in boost when I inject methanol (closed element sensor inside the intake manifold) and remove timing only in the 80+ kPa region when the IAT is high (summers or out of methanol) without affecting the idle or the low load regions.
The man behind MS Labs
