Evo 9 VVT support?
Evo 9 VVT support?
are there any plans to add support for the Evo 9 vvt? It uses the standard 4G63 crank/cam pattern, and just adds the usual VVT solenoid. It also has a cam sensor on the exhaust cam, which is the same as the intake cam but has an additional small tooth, but the exhaust cam sensor is not needed at all.
The man behind MS Labs
Re: Evo 9 VVT support?
also needing this support, I found out this in a bad way, I'm in another country and the MS is already installed and the engine running, it's planned to be tuned next week but I did not think the vvt would not have support so I'm asking for help.
I opened this thread in general support http://www.msextra.com/forums/viewtopic ... 31&t=66839
Megasquirted engines: 4g63, k24a2, b16-b18, duratec, ecotec, fiat 8v-16v, modular 4.6 32v, 1fz-fe, fiat 5cil 20v, Opel corsa, G54B, VW AG, 2ZZ-GE.
https://www.facebook.com/Bartonefi
instagram: @bartonefi
the intake tooth are regular tooth? If yes you can use standard vvt and you can use exhaust sensor cam for phase (use pull level)
Two uneven teeth.
the exhaust teeth are two uneven teeth but the intakes are 4 even spaced teeth, the problem is when you enable the vvt the TS shows an errorAbatelliCristian wrote:the intake tooth are regular tooth? If yes you can use standard vvt and you can use exhaust sensor cam for phase (use pull level)
Comp logs?
To support this the 4G63 mode would likely need to be re-written as it relies on the phasing of the cam pattern to the crank pattern.
Ok, the evo has exhaust cam sensor (fixed camshaft) and a intake cam sensor (variable) exactly as the honda k20, the K20 vvt with MS works with both sensors wouldn't the evo work like this?
You wouldn't believe, just right now the car has the engine on the floor because we had to change the crossmember, please allow me 1 or 2 days to make the logs.
I have oscilloscope logs from crank, cam1, cam2 and ign cyl 1 from a stock car if that helps.
Without seeing the composite logs, who knows?Barton wrote:wouldn't the evo work like this?
here it is
the car is ready for testing!!
hello, is there any news??
hello guys, I'm still here waiting please.
this is the project
precision 6466 1.15
dual tial 38mm
10.5:1 wiseco hd2 with manley I beam
kelford 280R
dual fuel rail (550cc +2150cc)
plasma coils
the medium range is awful, it really needs the vtc.
this is the project
precision 6466 1.15
dual tial 38mm
kelford 280R
plasma coils
- Attachments
- evo.jpeg (139.92 KiB) Viewed 1115 times
news for VVT support?
I would like to see this too.
I would have a few potential clients for this decoder also.. :O
any news???
I'm aiming to take a look next week.
Does anyone have a "Log crank and cam" composite log for one of these engines?
The log above is close, but doesn't give full data for the cam.
I know it is short notice to ask for this now, but I didn't realise that the log wasn't complete. I'm working on the code today.
I found I had some standard 4G63 data already, so I used that.
Test code sent.
Test code sent.
