Saftey feature suggestion T-Brake Lockout
How about some sort of lock out for trans-brake operation above a set mph? Or timed. Mph would be good for a street car application.
Re: Saftey feature suggestion T-Brake Lockout
i have set a programable output to be active below 5mph to a neg side of relay and use conventional switch for the positive on the coil
Maybe a test light could be used, but maybe with the launch disabled above X mph, it disbables the trans brake. If not, sure would be neat to see it tied together or it's own settings
Is that not In Launch Control/ 2-step.... --> "Disable launch when VSS1 is above (MPH): " ?
Does this still activate the brake, but not 2-step?
MS3Pro Ultimate
1994 Thunderbird SC
Fully Sequential, SVO Odd Fire V6
IGN-1A Coils - Brisk resistor plugs
12 magnet IW wheel (troubleshooting Holley 554-124)
Ford factory half-moon hall effect cam sensor
Using Dual Wheel non-missing tooth crank wheel strategy
Twin Turbo / TH400
1994 Thunderbird SC
Twin Turbo / TH400
That is unknown at this time. I'm close to getting my car on the ground and before hooking the brake up I'll test with a light to be sure. I'm hoping there tied together
