1.5.0. Using a 0-5v rotary pot connected to a tinyIOx.
I have the same setup on Boost control and it works fine.
The tooltip for the External Knob Input says to map a input to a generic sensor. But the drop down menu only allows for input selection, not generic sensor selection
As you can see here I can't select a generic sensor input. And if I setup a generic sensor then it can't be shared with the traction control settings.
Here is how it works for normal table blending, this seems to work fine for boost.
MSQ Attached. No datalog.
Traction Control External Slip % Input Bug
Re: Traction Control External Slip % Input Bug
Looks like a mistake in the tooltip.aidandj wrote:The tooltip for the External Knob Input says to map a input to a generic sensor. But the drop down menu only allows for input selection, not generic sensor selection
So 0v=0% and 5v=100%?
A there a way to log traction control slip % input?
Put it on a generic sensor and allow shared inputs.
Race car building documentation: www.kessel.tk (nice pics but only german laguage so far...)
