i think it would be great to have the possibility of switching/blending boost tables in depenancy of both ethanol content and gear based. On most applications traction is limited in the lower gears so gear based boost is a very great feature to help with that. But if you add a flex fuel sensor to get more boost dependant of the ethanol content there is no option to reduce the boost in lower gears. It would be great to be able to use the flex fuel sensor and also be able to adjust the boost targets by gear.
I would be very happy to have this option in the future.
Regards
Feature request flex blend + gear blend for boost
