Feature request : ALS Roving idle
as we all request features that enhance the functions by time , i see that the roving idle should be activated by a switch not to be always on , the user should enable ALS roving idle by switch and the ALS itself should be enabled by TPS vs RPM , this feature will give the user to cool down the engine with roving idle after ALS function and enable the user to use roving idle during race and exit this function after race as the car become impossible to drive in roving idle mode
Re: Feature request : ALS Roving idle
You could do it with table switching. We get this request fairly often. Street rodders and Harley people...
Andy
Andy
what you mean by table switching ? im talking about the roving idle function is only enable/disable by the tunerstudio not by switch
Oh, you want a bad idle all the time?
see http://www.msextra.com/forums/viewtopic ... 1&p=496926
or search for hunting idle or bad idle
Andy
Andy
Roving Idle is used when you have Have the throttle permanently jacked open in order to use Antialg without large air bypass valves or throttle kickers. Because of this there is no real need to have it activated by a switch.
Can you explain more about what you are trying to achieve.
maybe you could use a loop condition to do that instead of using a swtich?
