ms3x question
ms3x question
hi have the ms3x megasquirt got a problem it is configured for a hall cam sensor can i change this to a vr type sensor by altering the jumpers on the mother board
Re: ms3x question
There is a VERY detailed description in the Megamanual to help you complete whatever it is you wish with your Megasquirt. You can find it here http://www.msextra.com/doc/pdf/html/MS3 ... e-1.4.html or here http://www.msextra.com/doc/pdf/html/MS3 ... e-1.4.html depending on the board in question.
Wubba Lubba Dub Dub!!! oh. yea...
1985 Toyota Corolla 20V 4AGE MS3X Seq. Fuel/Spark...
1990 Eagle Talon TSi AWD 4G63 MS3X Seq. Fuel, Batch Spark...
Re: ms3x question
thanks for that i have managed to source an answer on the ms3x board the jumper jp7 needs to be removed and then in the loom connector pin 32 is signal from cam sensor and ground and sheild to pin 2
