Allow VSS recalibration without ECU reset?
Reverant
Post by Reverant »
I get this request quite often. People who want to calibrate their VSS ask me to somehow make the recalibration easier by not requiring an ECU reset when the pulses per mile or the full scale speed changes (as it requires you to coast down or switch the ignition off/on while driving which I don't agree with).
Is this possible?
The man behind MS Labs
AbatelliCristian
Re: Allow VSS recalibration without ECU reset?
Post by AbatelliCristian »
nathaninwa
Post by nathaninwa »
I thought this same thing just last week. I needed to drive my race car around the neighborhood and play with tire size to get vss to match for traction control, took 5 trips around the block and multiple stops and refires to get it right
I'm not sure what things require a hard reset, but can there be such a thing as soft reset and when done a final hard reset can be done?
93supercoupe
Post by 93supercoupe »
Would be nice to see it not require a hard reset.
BootlegTuned
Reverant
Post by Reverant »
I haven't checked the code but I think the reason the reset is necessary is because some form of calculation that is used afterwards is done during the bootup/init phase. It's not done in the main loop afterwards to save CPU time, hence the required reset. The new "Reset button" may help somewhat here but I would really prefer a live calculation.
