The fuel density correction table exists and seems active, but the manual says (and TS grays out the boxes) it's not active unless dual fuel is selected.
It seems the ~%6 reduction from -40F to 120F (for either gasoline or ethanol) would be still a thing even if not running dual fuel.
Also, the inputs are listed as sensor1, sensor2 etc, which one is the flex input?
Or is the table active because I have the flex temp sensor input active?
Running ms3-pre1.5b2
Fuel density correction using ethanol sensor?
Re: Fuel density correction using ethanol sensor?
I tested and I'm able to get the curve ungreyed.
