MS3 pre-1.5.1 beta 4 firmware released
Re: MS3 pre-1.5.1 beta 4 firmware released
has the "flex multiplier %" rollover past 152% to 100 been addressed yet?
I think so, but could you remind me of the topic where MSQ/MSL are posted and I'll double check.ashford wrote:has the "flex multiplier %" rollover past 152% to 100 been addressed yet?
- puntogt4
Problem find, maybe can help someone,puntogt4 wrote:Today I load a old beta, 14.2, and vss come back again, I think the problem is on PT4 input, because by choose it for vss you can't set high option "speed input", like shaft speed, if there you don't set "high speed" I don't see any speed on tuner studiopuntogt4 wrote:I have problem for VSS1 setup,
on my car is connect to PT4 and i don't read any speed,
but if I set shaft speed to PT4 and high speed setup like on my MSQ I'm able to read the rpm's
now I cant go back to my old version because i lost the firmware -_-
Nobody have same problem to rat the speed from PT4 input?
on attach msq and relative log
Inviato dal mio HUAWEI NMO-L31 utilizzando Tapatalk
problem was on tunerstudio, ofter reflash many time the cpu whit varius beta and relaise
my project on tuner studio give error, make a new project an vss start to work normally
is very strange because every time i loat a any firmware older than 1.4 vss work fine
I also try on laptop before I can't see vss making a new project vss are working again!
Fast Only Rolling Down
jsmcortina wrote:I think so, but could you remind me of the topic where MSQ/MSL are posted and I'll double check.ashford wrote:has the "flex multiplier %" rollover past 152% to 100 been addressed yet?
sorry i missed this. here is the older post http://www.msextra.com/forums/viewtopic ... 20#p500303
Good info on the flex. I will investigate.
Flex changes now committed.
James,
Can you also add pt4 or other fast pwn input to flex as we discussed before ?
Thanks,
Manu
Thanks,
Manu
So I'm understanding this correctly. Closed loop Dome Control will follow the Bias table until your delta and then it will do what it has to do to compensate?
Yes.LSXCutty wrote:So I'm understanding this correctly. Closed loop Dome Control will follow the Bias table until your delta and then it will do what it has to do to compensate?
James, This post got bounced around a bit before it was moved to MS3 Development. Apparently its firmware related and not TunerStudio as I had initially thought. Can you confirm if it is a firmware issue?
VVT settings not highlighted in feature list
MS3-Pro 1st Gen | Honda K24 Supercharged
MS3/MS3X | SB Ford 347 stroker
