Feature Request - Load Dialog change
nd_mustang
Post by nd_mustang »
I would like to be able to "Save Dialog" for, say, "Table 1" for fueling, and then "Load Dialog" and load the same numbers into "Table 3". Right now it won't do that.
Re: Feature Request - Load Dialog change
Post by Matt Cramer »
This should work with the Table Export and Table Import buttons. If not, you may want to post this in the TunerStudio section of the forum as this is related to the tuning software and not the firmware.
LT401Vette
Post by LT401Vette »
nd_mustang wrote:I would like to be able to "Save Dialog" for, say, "Table 1" for fueling, and then "Load Dialog" and load the same numbers into "Table 3". Right now it won't do that.
In every dialog there is a file menu.
That file menu has basically exactly what you are describing "Load Dialog Settings" and "Save Dialog Settings"
If you use that option to save, if save only the settings in that dialog to a .msqpart file.
The Load Dialog Settings lets you load either a .msqpart file or a full msq. If it is a full msq, it will still only load the settings in that dialog, all other settings in the msq will not be loaded.
There is more on this in the Help under "Single Dialog Save / Load"
Note: This feature is only in the registered version.
KeithBoden
Post by KeithBoden »
Rebin the destination table first if you want that to match. It is only 16 numbers and the tab key works nicely. Then:
1. Open Table 1
2. Select (highlight) all the cells
3. Ctrl-C
4. Open Table 3
5. Select the top left cell (may not even have to do that, I just do)
6. Ctrl-V
Camaro, Mark IV aluminum big block Chevy, 8.8l, Procharger F1-R @ 12psi, MS3Pro
