Dwell voltage correction
I see on TS the dwell voltage correction will not let me increase any more than 18 volts. I have a 16 volt (18.4 volts with the engine running) system.
Re: Dwell voltage correction
You may have to mode the .ini file to allow larger values.
page 5. in the ini file
dwellvolts = array , U08, 794, [ 6], "V", 0.10000, 0.00000,6, 18, 1 ; * ( 6 bytes)
change the 18 to 20 or 18.4 to get your full range.
do "ctrl f" and type in dwellvolts. the search should find this line. Just edit it and save, close/reopen TS.
missed one. also here.............
change the 16 to 20.
Code: Select all
curve = dwellSettings, "Dwell Battery Correction"
topicHelp = "file://$getProjectsDirPath()/docs/Megasquirt3_TunerStudio_MS_Lite_Reference-1.5.pdf#dwellbat"
columnLabel = "Voltage", "%age"
xAxis = 6, 16, 6
yAxis = 0, 500, 6
xBins = dwellvolts, batteryVoltage
yBins = dwellcorr
