VVT settings not highlighted in feature list
jsiedlicki
Post by jsiedlicki »
I could have sworn I posted this yesterday, but it is not showing up, so here it is again.
This is on an MS3-Pro and 1.5.1 beta 4 firmware
I am setting up a Subaru flat 6 that uses VVT on all four cams. When I configure the VVT settings and then look over under "Feature List Showing I/O pins", the input and output for VVT4 and the input for VVT1 are not highlighted as if they are not configured? See pics below. Tune is attached if needed.
MS3-Pro 1st Gen | Honda K24 Supercharged
MS3/MS3X | SB Ford 347 stroker
racingmini_mtl
Re: VVT settings not highlighted in feature list
Post by racingmini_mtl »
jsiedlicki wrote:I could have sworn I posted this yesterday, but it is not showing up, so here it is again.
You did. It has been moved to the MS3 beta forum: http://www.msextra.com/forums/viewtopic ... 26&t=67015
jsiedlicki
Well since I get this error message when clicking the link you provided, its not much help.
"You are not authorised to read this forum."
What is that about?
Plus, I do not see it in the MS3 beta forum? In fact there is no forum numbered 126 in my list.
racingmini_mtl
Good point. That's an old forum that was used many years ago and has limited access. So whoever moved your post moved it there by mistake. I guess the intent was to move it to the MS3 development forum because that would be more of a firmware related issue than a TS issue.
Unfortunately I don't have any useful information to provide concerning your issue but hopefully someone who does will respond and not move the post to a restricted forum.
Post by LT401Vette »
Yes, that should have been moved to MS3 Development. The MS3 Beta forum hasn't been used since the 1st MS3 Beta firmware.
