I could have sworn I posted this yesterday, but it is not showing up, so here it is again.
This is on an MS3-Pro and 1.5.1 beta 4 firmware
I am setting up a Subaru flat 6 that uses VVT on all four cams. When I configure the VVT settings and then look over under "Feature List Showing I/O pins", the input and output for VVT4 and the input for VVT1 are not highlighted as if they are not configured? See pics below. Tune is attached if needed.
VVT settings not highlighted in feature list
MS3-Pro 1st Gen | Honda K24 Supercharged
MS3/MS3X | SB Ford 347 stroker
Re: VVT settings not highlighted in feature list
You did. It has been moved to the MS3 beta forum: http://www.msextra.com/forums/viewtopic ... 26&t=67015jsiedlicki wrote:I could have sworn I posted this yesterday, but it is not showing up, so here it is again.
Well since I get this error message when clicking the link you provided, its not much help.
"You are not authorised to read this forum."
What is that about?
Plus, I do not see it in the MS3 beta forum? In fact there is no forum numbered 126 in my list.
What is that about?
Good point. That's an old forum that was used many years ago and has limited access. So whoever moved your post moved it there by mistake. I guess the intent was to move it to the MS3 development forum because that would be more of a firmware related issue than a TS issue.
Unfortunately I don't have any useful information to provide concerning your issue but hopefully someone who does will respond and not move the post to a restricted forum.
Yes, that should have been moved to MS3 Development. The MS3 Beta forum hasn't been used since the 1st MS3 Beta firmware.
