- Dual Fuel Enable: On
- Mode: Flex blend
- Alt. Fuel Tables: On
- Alt. Spark Tables: Off
- Spark Table Switching: On
- Switch Source: Hardware
- Input Pin: Blend Curve (4)
However, Ignition Table 3 (and 4 if the 2nd ignition algorithm is enabled) appears grayed out in the menu. I suggest the following change to the ini file:
Current ini (1.4 and 1.5)
Code: Select all
subMenu = ignitionTbl3, "Ignition Table 3", 0, { (!dualfuel_sw_on && f5_0_tss) || (dualfuel_sw_on && dualfuel_sw_spk) }
subMenu = ignitionTbl4, "Ignition Table 4", 0, { (IgnAlgorithm2 !=0) && ((!dualfuel_sw_on && f5_0_tss) || (dualfuel_sw_on && dualfuel_sw_spk)) }
Code: Select all
subMenu = ignitionTbl3, "Ignition Table 3", 0, { (!(dualfuel_sw_on && dualfuel_sw_spk) && f5_0_tss) || (dualfuel_sw_on && dualfuel_sw_spk) }
subMenu = ignitionTbl4, "Ignition Table 4", 0, { (IgnAlgorithm2 !=0) && ((!(dualfuel_sw_on && dualfuel_sw_spk) && f5_0_tss) || (dualfuel_sw_on && dualfuel_sw_spk)) }
