Autosport Labs AnalogX
lifeandffl
Post by lifeandffl »
Hi all, first new thread. I was wondering if anyone can give me some incite on how to code up for a AnalogX GPIO from Autosport Labs. It was built and designed to add on additional channels for the RaceCapture/Pro but I wanted to integrate it into my MS3X. I was thinking I could use the GPIO code that is already existing and modify it to work with the AnalogX. Is this a reasonable approach or do you have another suggestion?
A link to the device I want to use is below.
https://wiki.autosportlabs.com/AnalogX
Thanks,
-Joey
grom_e30
Re: Autosport Labs AnalogX
Post by grom_e30 »
it looks like you could use the can receiving to read the data from that guy.
lifeandffl
grom_e30 wrote:it looks like you could use the can receiving to read the data from that guy.
That was my thoughts as well. Now I just need to figure out HOW I go about doing that.
I guess I'll just have to dive into the code and figure out how to get the two to talk to each other.
-Joey
grom_e30
Post by grom_e30 »
it shouldn't need any firmware coding.
by default it broad casts the data at 50hz on a 500kbp can speed so this is good as its the baud megasquirt uses, it looks like it uses 2 bytes per sensor i'm guessing its a unsigned integer little endian format and i believe it uses 0-5000mv for the reading it gives out.
see here: http://www.msextra.com/doc/pdf/html/Meg ... 5-279.html
http://www.msextra.com/doc/pdf/html/Meg ... 5-235.html
so between the can receiving and the generic sensor inputs you should be able to read you 0-5v input from the AnalogX then scale it in to human readable information and log or display it
