to add always on option to the launch control(2 step).
just for example
always on below __% vss
and above __% tps
it will work the same without the need to flip a button and it will free us a ecu input for other things.
Feature request:Launch control always ON
Re: Feature request:Launch control always ON
You can use a loop condition instead to achieve that... See in the Programmable ON/OFF Outputs
found it
thank you sir.
thank you sir.
