Feature request:Launch control always ON
atias
Post by atias »
to add always on option to the launch control(2 step).
just for example
always on below __% vss
and above __% tps
it will work the same without the need to flip a button and it will free us a ecu input for other things. :idea:
Suprazz
Re: Feature request:Launch control always ON
Post by Suprazz »
You can use a loop condition instead to achieve that... See in the Programmable ON/OFF Outputs
atias
Post by atias »
found it :)
thank you sir.
