Feature Requests - Individual Wideband Calibrations and more
Postby CMac89 » Mon Oct 09, 2017 7:33 am
1. Individual AFR Calibration tables per sensor - I'm running two different widebands, one being Zeitronix and the other is Innovate, however, since they do not have the same linearity, there is a shift in the one bank's AFR due to not being able to assign a calibration to each sensor.
2. Individual cylinder trimming being part of VE analyze - this would be great. I am running one wideband per bank and, considering the issue with number one here, one bank is 1.0 AFR points leaner than the other bank; therefore, I trim the cylinders in the lean bank to add fuel to catch up with richer bank. It would be great if that percentage was automatically calculated. What i do is have the VE table calculate based on one bank's AFR, then I trim the other bank.
3. Misfire detection - it would also be great to have a way to detect which cylinders are misfiring.
MS3Pro
1994 Thunderbird SC Fully Sequential SVO V6
Versafueler Peak and Hold Injector Driver
IGN-1A Coils
DIY Cherry Crank Sensor with Ford half-moon hall effect cam sensor
DIY 36-1 toothed crank wheel
1500hp goal!
CMac89
Re: Feature Requests - Individual Wideband Calibrations and
Postby CMac89 » Wed Nov 01, 2017 7:57 pm
Any feedback for number one and two mainly??
MS3Pro
IGN-1A Coils
1500hp goal!
CMac89
Return to MS3 Development
