Mitsubishi 36-2-1-1 6G75 trigger wheel support request
Posted: Sat Oct 21, 2017 10:11 am
I do not have a .msq file to attach
This wheel is not found in any 6g74 engines, but could be swapped over.
I think that wasted spark is ok, however if you want I could get a pic of the cam trigger wheel too. (for full sequential injection/COP non-wasted) BONUS: how to activate VTEC solenoid??? (requires 12v peak&hold @~400hz pwm if I remember correctly.
(yes, this motor has Honda-style Vairable Lift on BOTH intake valves)
(This is totally different then the MIVEC engine found in the Evo9)
Let me say this again, the 4g63 EVO has VVT, while the 6g75 Eclipse has "cam lobe switching"
This should be easy to add to the database. This trigger wheel is used in all 6G75 motors (except the Montero 6g75)This wheel is not found in any 6g74 engines, but could be swapped over.
