Mitsubishi 36-2-1-1 6G75 trigger wheel support request
iceminion
Post by iceminion »
I do not have a .msq file to attach
picture of 3000GT with Eclipse 6G75
This should be easy to add to the database. This trigger wheel is used in all 6G75 motors (except the Montero 6g75)
This wheel is not found in any 6g74 engines, but could be swapped over.
I think that wasted spark is ok, however if you want I could get a pic of the cam trigger wheel too. (for full sequential injection/COP non-wasted)
half-resolution of original trigger wheel image
XX 6g75 trigger wheel with green highlights.jpg (164.08 KiB) Viewed 252 times
BONUS: how to activate VTEC solenoid??? (requires 12v peak&hold @~400hz pwm if I remember correctly.
(yes, this motor has Honda-style Vairable Lift on BOTH intake valves)
(This is totally different then the MIVEC engine found in the Evo9)
Let me say this again, the 4g63 EVO has VVT, while the 6g75 Eclipse has "cam lobe switching"
