O2 signal - backpressure compensation
Postby thedrew » Wed Oct 25, 2017 4:21 pm
I see an old thread in 2012 about this, but nothing since then.
For those of us wanting to monitor O2 before the turbo, this would save us buying an external unit to do the compensation for us.
Was wondering if this is planned or somehow managed already?
VW Manx 2276cc Turbo MS3X sequential
Watercooling is a fad, it'll pass.
thedrew
Re: O2 signal - backpressure compensation
Postby racingmini_mtl » Wed Oct 25, 2017 5:28 pm
The O2 compensation has to be done by the WBO2 controller because that is dependent on the Nernst cell current inside the sensor. This is not visible externally so it cannot be done in the MS3.
So you need a controller that supports this. The MegaSpartan from 14point7 does support it and is designed for easy integration with the MS3. There are likely others but I'm not familiar with them.
racingmini_mtl
Postby thedrew » Thu Oct 26, 2017 2:09 pm
thanks. I'll look into Alan's solution -- he says the backpressure stuff isn't done yet, but in a couple months the new firmware will be out.
The AEM 4-channel CANBUS unit uses the LSU 4.2 sensor. A rep said using the LSU 4.9 sensor is "on the horizon" -- whatever that means.
thedrew
Postby chips60bug » Thu Oct 26, 2017 8:31 pm
thedrew wrote:thanks. I'll look into Alan's solution -- he says the backpressure stuff isn't done yet, but in a couple months the new firmware will be out.
Have you heard from him on this recently?
chips60bug
Postby thedrew » Fri Oct 27, 2017 8:05 am
yeah, i emailed him about it this week and got this:
The pressure compensation feature is still being worked on, a new firmware will be released in about 2 months. The firmware is end user updateable.
I will carry and sell the pressure sensor once the new firmware is released.
thedrew
Postby chips60bug » Fri Oct 27, 2017 8:11 am
Good to know. I have firmware in mine right now that is supposedly doing the comp stuff. I sent some datalogs to him early this week, hopefully he can do good things with what I gave him, cuz my car is done for the season, requiring some pretty major TLC.
chips60bug
Postby thedrew » Fri Oct 27, 2017 8:15 am
Yeah, I'm about ready to pull the trigger on the megaspartan -- my cars done till the spring, so I hope the firmware is done by then.
I can't decide if I want the 5 channel (to pick up the average) or is the 4 channel all I'll ever need.
thedrew
Postby chips60bug » Fri Oct 27, 2017 9:26 am
I use the 4, with an outside 5th till i trust the device. The computer creates an average and uses it to tune your ve table with. Running a 5th will be difficult to do and not confuse the computer. I currently run my 5th as a generic sensor, i feed it direct to the IOX over serial, then i convert that signal to a 0-5v and use an ADC from the IOX to the MS3 as such. I then just input the Innovate calibration data and created a gauge. That way it doesn't have any affect on the tune. It responds later than the per cylinder devices do, so it definitely made tuning tricky back when i had it listed as a 5th ego.
chips60bug
Postby thedrew » Fri Oct 27, 2017 9:34 am
chips60bug wrote:I use the 4, with an outside 5th till i trust the device. The computer creates an average and uses it to tune your ve table with. Running a 5th will be difficult to do and not confuse the computer. I currently run my 5th as a generic sensor, i feed it direct to the IOX over serial, then i convert that signal to a 0-5v and use an ADC from the IOX to the MS3 as such. I then just input the Innovate calibration data and created a gauge. That way it doesn't have any affect on the tune. It responds later than the per cylinder devices do, so it definitely made tuning tricky back when i had it listed as a 5th ego.
good to know, thanks!
thedrew
Postby 93supercoupe » Tue Jan 02, 2018 8:41 am
I found this info on the LSU type sensors. Maybe this info could kick off the implementation of this feature request.
Last page has temp/pressure curves
Y258K01005e03mar21eng (1).pdf
(277.63 KiB) Downloaded 17 times
1988 BMW 325, m52, s52 cams, HX35/HX40 hybrid, MS3x, 537whp/509wtq on 22PSI, pump gas, stock engine
1998 BMW M3 Sedan, Lq4 6.0, twin ebay 66's, Ms3 Gold box, 770whp/750wtq 19psi
1998 BMW 328i Sedan, forged lq4, twin Borg s366's, built th400, MS3 Ultimate, 9.2 at 150 on 22psi
93supercoupe
Postby shaodome » Mon Jan 15, 2018 7:16 am
racingmini_mtl wrote:The O2 compensation has to be done by the WBO2 controller because that is dependent on the Nernst cell current inside the sensor. This is not visible externally so it cannot be done in the MS3.
Are you saying the Megaspartan has compensation based on pressure as a feature? That would be amazing, but I just checked the documentation on it and can't find any reference to backpressure compensation. Temperature control, yes...compensation for pressure, not that I can find....yet?
shaodome
Postby 93supercoupe » Mon Jan 15, 2018 9:27 am
I emailed them, its coming in spring they said. Looks like a firmware flash more then hardware from what i gathered.
93supercoupe
Postby shaodome » Mon Jan 15, 2018 5:03 pm
93supercoupe wrote:I emailed them, its coming in spring they said. Looks like a firmware flash more then hardware from what i gathered.
technically could probably grab the data needed for that off the MS CAN BUS. REALLY looking forward to this product.
shaodome
Return to MS3 Development
