Boost Control Settings, 250Hz possible?
Turbolu
Post by Turbolu »
Hello together,
I have a concern, I would like to operate an electric WG controller, this requires 250Hz.
I use an MS3 with the current firmware, in the Boost Control Settings I can only select "mid" "... 153Hz, 204Hz, 306Hz ...".
In the "Generic PWM Output" I can select 250Hz, so runs the controller. "Only" the map is smaller in the "Generic PWM output" and I can´t drive a CL control.
Does anyone have an idea how I get the problem solved?
Greets from Germany
VW Golf 2 4 Motion 2,1l 16v Turbo Tracktool
Porsche 911 VTG Turbo
MS3x
Vollsequ, 4x EGT
8x Injektor
CANbus Board
Turbolu
Re: Boost Control Settings, 250Hz possible?
Post by Turbolu »
Hello again,
Now the Engine runs, but the Porsche VTG Turbo needs 250Hz... It would by nice if can usw the boost table to use Closed Loop with the 250Hz
At worst case I must take an Arduino to confert 306Hz to 250Hz
Edit:
MS3 1.5.0 release
TS Ultra V3.0.28
MS3x
Vollsequ, 4x EGT
8x Injektor
CANbus Board
TurboBob
Post by TurboBob »
is this a solenoid you are trying to control, or an electric motor style actuator?
B
Turbolu
Post by Turbolu »
it is an Siemens E-Actuator (Original Porsche 997 Turbo)
If it is not possbile, i will take an Arduino to make 1021Hz to 255Hz
MS3x
Vollsequ, 4x EGT
8x Injektor
CANbus Board
Paul_VR6
Post by Paul_VR6 »
Have you tried 204 or 306? I have seen most devices work fine over a range of control frequencies.
-Paul
Turbolu
Post by Turbolu »
Hello Paul,
it only works at 243Hz-257Hz
Why it is possible to select 250Hz in the "generic PWM " and not in the Boost seetings?
MS3x
Vollsequ, 4x EGT
8x Injektor
CANbus Board
Turbolu wrote:Why it is possible to select 250Hz in the "generic PWM " and not in the Boost seetings?
Boost control is using hardware PWM which has a fixed set of frequencies depending on the dividers used. The list in MS3 isn't all of the possible frequencies though.
The generic PWM is using software PWM and can use a wider range but typically slower and less precise frequencies.
Turbolu
Post by Turbolu »
James,
Can you help me ti fix the problem with 250Hz in the boost Control? :|
I don't like to use an Arduino, but i like to use my Porsche VTG turbo on my Golf 16v engine and have a good boost control :mrgreen:
MS3x
Vollsequ, 4x EGT
8x Injektor
CANbus Board
Turbolu
Post by Turbolu »
now it runs :D
I took in the "Generic PWM B" for the Y Axis "Boost duty" and the "Boost control settings" I choose a "blind" output.
MS3x
Vollsequ, 4x EGT
8x Injektor
CANbus Board
MWPau
Post by MWPau »
Nice work :)
