shift light VSS based
Postby AbatelliCristian » Tue Nov 07, 2017 10:44 am
Hi guys,
I have question.
In drag race FWD the shift light rpm based is useless, because the engine, for half time, is near revlimiter or in revlimiter for tire slippage.
My idea is shiftlight based VSS. 4 or 5 breakpoint where lighit is on for 1 second.
ES.
VSS = 80kmh Light on for 1 sec
VSS = 140kmh light on for 1 sec
VSS = 190kmh light on for 1 sec
obviously the vss sensor will be in the rear wheels
Regards
Cristian
AbatelliCristian
Re: shift light VSS based
Postby goodysgotacuda » Tue Nov 07, 2017 2:06 pm
Could you use a pwm output based on vehicle speed?
Instead of on for “1sec” have the duty cycle be 100% from 80km/h-85km/h or so. It’ll tak3 you a second or less to get there depending on your acceleration rate. That could also give you a pre-shift pulse of light just before it goes solid, if you wanted.
MS3 Gold Box
I'm new to Megasquirt!
goodysgotacuda
Postby AbatelliCristian » Tue Nov 07, 2017 2:22 pm
mmmm with generic pwm there are few breakpoint....
I can use loop in the programmable output on-off.
AbatelliCristian
Return to MS3 Development
