Like the title says it would be nice to have the option to blend 2 boost / speed tables with flex fuel.
Sent from my SM-G930F using Tapatalk
Feature request: blending 2 boost/speed tables with flex
Re: Feature request: blending 2 boost/speed tables with flex
Bump.
I would love it if we could get this.
Thanks in advance.
Thanks in advance.
agreed.. We need a flex fuel boost variable table..
-Sam
-Sam
Maybe you guys can help me here?
http://www.msextra.com/forums/viewtopic ... =flex+fuel
[quote]Megasquirt flex fuel.... is there a flex blend curve for spark? Boost? When using alternate Req_Fuel, will it also blend according to the single "flex_blending" curve, or will it straight blend from req_fuel to alt_req_fuel proportionally to ethanol percentage?
Your alternate AFR target stays in gasoline AFR since we are blending the req-fuel and don't need a second multiplier?
My fuel calculation summary always had 106 in e85 fuel correction even before I enabled flex fuel. Why?[quote]
Bump
Sent from my Pixel 2 XL using Tapatalk
