Feture Add: GM BCM CAN Engine Start/Stop
Postby nvr2fst » Tue Dec 05, 2017 6:55 am
I have a CAN Sniff tool and can work on decoding the factory engine start/stop command so I can completly remove my stock ECU(no more piggy back stand alone for C6 Corvette)
That would be a HUGE advantage over other ECU's for the MS3. The question is: If I do the work to find the start/stop/acc/run command sequence from the BCM will you guys create a CAN Engine Start/Stop section in the software?
-Josh
nvr2fst
Return to MS3 Development
