Feature request EGO Correction add fuel only
Posted: Sat Dec 09, 2017 6:54 pm
I was a PRI in the last few days at the DIYAutotune/AMPEFI boot and a customer requested this and I liked the idea.
We want to be able to specify ego correction to only add fuel and not remove it. Actually, the authority number is a +/- % so if you authorize 10%, it can add up to 10% more fuel but can also remove 10% fuel too.
It would be great to be able to specify a different maximum correction authority on both add and removing fuel. Holley does that. So you can tell your ego correction to only have the right to add fuel at idle and not remove fuel.
Maybe a simple solution, for now, would be to add another menu to the ego options to specify how the authority percentage (or table) work with 3 options. It can add both and remove fuel, only add fuel, only remove fuel.
Let me know what you think.
