Feature request- pneumatic/electric shift solenoid control
93supercoupe
Post by 93supercoupe »
Setting up a twin turbo glide G body on a ms3 ultimate and the owner has an air shifter. I’m realizing now there’s no good way to control this.
For now, we have it using a programmable output based off rpm and vss but if this were a 3 speed, that wouldn’t work.
With the ultimate/Evo products having a ton of i/o, it doesn’t make sense to have to buy another controller when it seems like this could happen in the software.
We would need some way to plot multiple vss/rpm/tps points to capture this.
I haven’t thought of a great way to do this, so I’m looking for ideas.
BootlegTuned
Re: Feature request- pneumatic/electric shift solenoid contr
Is there any way you could use the bike shifter sequential shift cut feature? That has an automatic mode.
93supercoupe
That’s a much better option then the programable outputs for sure.
But if it could have a minimum vss like it has a minimum rpm and also a and/or vss feature for each automatic shift point. (Loose converters)
And if we do vss based stuff, maybe selectable vss input (Incase of tire spin, you could use vss 2)
BootlegTuned
