MS3X in Jeep V8
Re: MS3X in Jeep V8
I have checked the lower connector and it has 12.2 volt...
I attached a file with the PC setting.
Thanks.
Re: MS3X in Jeep V8
Can you try running the portcheck.exe program with the MS3 plugged in and powered up, and post the results?
Re: MS3X in Jeep V8
Ok, here is:
Re: MS3X in Jeep V8
Ok, it's not responding to the normal port check commands. What if you put the boot jumper in place and try again?
Re: MS3X in Jeep V8
I'm sorry, it was without any file opened in MS3...I will do again.
Re: MS3X in Jeep V8
This is.
Re: MS3X in Jeep V8
TunerStudio needs to be closed when running Port Check, as it can tie up serial ports.
Re: MS3X in Jeep V8
Was that with or without the boot jumper in place?
Re: MS3X in Jeep V8
I haven't opened the MS3 box.
Can you explain me a bit about boot jumper or give me a link about that?
Re: MS3X in Jeep V8
See:
http://www.msextra.com/doc/ms3/firmware.html
and http://www.msextra.com/doc/ms3/pix/ms3-jps.gif
Re: MS3X in Jeep V8
I have bridged the two pins of the boot jumper and then I've run the portcheck. I attached the results.
Re: MS3X in Jeep V8
As the screenshot shows you need to install firmware.
Re: MS3X in Jeep V8
Ok, Thanks.
Re: MS3X in Jeep V8
Re: MS3X in Jeep V8
Was that with the boot jumper still attached? It needs to be.
Re: MS3X in Jeep V8
Alleluia!!!
I already have connection with the MS3.
Thank you!!!!!
Thank you!!!!!
Re: MS3X in Jeep V8
I'm trying to set the IAC motor, but it isn't able to get the target rpm.
I attached the setting configurations.
Re: MS3X in Jeep V8
See "Read help page here."
Re: MS3X in Jeep V8
Ok. This is my firs datalog...
