Strange signal loss and sync loss 2 after MS3 1.3.2 upgrade
I have very strange issue and it comes when the engine is warm after I was driving.
If I start the engine the RPM drops and the engine want to die but after about 10 seconds it runs as normal again, veru smooth.
But if I turn the key off and start again I get the same issue .
When the engine is cold it starts just perfekt and no signal loss
any ides?
any ides?
Mercedes 300E Turbo MS3X 1150hp
http://www.turbobandit.com
http://www.youtube.com/user/PUMPISH
https://www.facebook.com/pages/Turboban ... 24?fref=ts
Re: Strange signal loss issue at the start
can you post a msq and a composite log?
here comes msq and tomorow and can fix composit log, but I checked composit log today and could not se any misses, I all try tomorow again.
Most of all this essue comes after I was driving hard and the engine is real hot.
Actually I have had the same essue in a couple of years already and just not had the energy to bother me because the essue disappear after 10 seconds after the engine has started.
But now the man a little tired of it
NEW UPDATE
today the car has the same issue all the time when i start the engine.
Cold and warm engine the same issue, each time I start.
I made a few composit log but and sync loss log and it show nothing.
BUT when I remove the cam sensor connector then it starts perfect without cam sync
So it is something with a cam sync, it takes about 10 seconds to work well, dont understand why
Log shows synd loss reason 17 (second trigger not found when expected ) many times
now I installed new cam sensor but stil the same issue
composite log?
I coult not upload it because it got bigger then 1 mb
I the signal on composit log looks look and shows no sync loss.
I can try to log again shorter one
you can zip them to save space.
new update, new issue!
I updated firmware to MS3 1.3.2 and now the cam sync issue is gone! Engine starts perfect every time!
But I have a new issue instead.
When I boost at the 3th gear and coming at higher rpm everything just dies!
Engine just dies and tunerstudio dies too.
When I check log everyting drops when I get sync loss 2 , misssing tooth at the wrong time.
It happens only when i boost at 3th gear with no spinning
Re: Strange signal loss and sync loss 2 after MS3 1.3.2 upg
I have browsed through my old logs and discovered something.
I had not lost sync until I switched to the newer firmware for the first time. After that I got lost sync reason 2 in each log.
Before I switched to the newer code so the car has worked flawlessly for 2-3 years daily
