trying to get my 1jzgte supra running
hello everyone I need some help I just got my ms3x and installed on my 89 supra with a 1jzgte
so heres my problem I cant get the car running sometimes it will start and then just die I am learning how to adjust the pots as i go here is my tune and a few compose logs..
im only running the rear cam sensor
mods mk4 550cc injector
t61 comp turbo ttb
legend resistor box
t61 comp turbo ttb
legend resistor box
Re: trying to get my 1jzgte supra running
Any help will be appreciated
Can you post a regular data log as well? The composite log is just for checking RPM input problems.
yes I can and I have been trying to adjust a few more setting so here is an updated tune also
First, check the timing with a timing light while cranking.
Second, try adjusting the afterstart enrichment.
We have an in-depth article on startup tuning here: http://www.diyautotune.com/tech_article ... uning.html
Ok while cracking it said 10 once it startes it goes higher once it warmed up I went to set timing and car dies and I can't get it to start back up
an update when it get warm and I cant get it to start I have a lot of sync lost so as of right now I reading up on the vr adjustment and trying to get it dialed in
Update I got the car running on cold start and warm start still needs some adjusting but it's getting closer thats for all the links and help
From one 1JZ owner to another:
The stock 1jz wiring is over + 20 years old now, and full of noise. So if using stock wiring - at least replace the Cam and Crank sensor wire with shielded wire like DIY delivers in their wiring kits.
I'm running with no trim-pot adjustment (fully ccw), with no issues.
What coils are you running?
Stock (dumb) coils dont like more than 2,5ms of dwell. Anything over, and they just overheat.
If you need more spark power, go for a smart coil.
Toyota JZX90 Mark II drifter
1JZ-GTE, 12+1 on MS3x, 6x LS7 D514's, 510cc, all stock sensors
Ok thanks for the info i am not using the stock harness I took it all out and yes I'm ran shielded wire for my cam sensor crank sensor and knock sensors also I'm running lq9 coils also when you say fully ccw is that on all pots or just r52 and r56?
Correct.
R52+R56 (Mainboard) and R11+R32 (ms3x)
All fully CCW is working like a charm om my setup.
Ok that's but I guess I found some of my problems I found leaking injectors so as of right I'm upgrading to new injectors
