BMW S62B50
Re: BMW S62B50
Hi guys,
I think monday I can make new test in s54.
Ragepower, how many tooth do you have in cam? the decoder is equal s54?
Re: BMW S62B50
AbatelliCristian: these are mine cam decoder
https://www.dropbox.com/s/45yrvb24ux6aq ... 9.png?dl=0
James, these are the videos I made. The upper line is the inlet, the bottom the outlet. The scale is 10v/div.
I had done a mistake, has changing the ms/div (between 1, 2, 5 ms) . I has trying to get both pulses. When the line is continuous is a 1 ms. I notice the pulse width was almost the same.
https://www.youtube.com/watch?v=YSfA8WV ... e=youtu.be
On this, I just change between, 1 and 2 ms.
https://www.youtube.com/watch?v=lZ-XaPr ... e=youtu.be
Do you need more videos?
EDIT: Doing thing without time, turn in to mistakes. On videos, both are for the same cam (inlet), the upper is the advance, the bottom is the retard.
Re: BMW S62B50
Additional Info:
On S52 and S50 Euro-Models (same controll) I am seeing in Diagnostic-mode approx. 150ms from one extreme to the other...
S50 has only the inlet cam vanos controlled but the principle with the two valves is the same.
Race car building documentation: www.kessel.tk (nice pics but only german laguage so far...)
Re: BMW S62B50
Thank you thokes82
James: do you need more information/scope?
Another thing I will need is high-side drivers for vanos solenoids and a few more things.
After searching on the internet, I found this circuit on diyautotune:
Is it enough or it need to be something specific?
Re: BMW S62B50
Hi james
Will it possible MS to control this vanos since it can control a S54 vanos?
Is TIP125 enough to vanos solenoids?
Re: BMW S62B50
The control code works, so that's a start. Handling 8 PWM outputs is the technical challenge here. Luckily they work ok at 20Hz.
Re: BMW S62B50
Great. Like I said before, If you accept the challenge, I want to help you.
First tell me if the tip125 is enough to vanos control, so I can procced with the hardware.
These are the outputs I need, besides the injectors and igniton coils:
- 8 vanos (20Hz, high-side)
- 2 Idle (3-hire idle valve 100hz, low-side)
- 1 vanos pressure accumolator solenoid (100hz with 15% Duty-cycle on a generic PWM output, high-side)
- 3 on/off outputs (fan, shift-light (optional))
Re: BMW S62B50
OK I have knock module, so I can't use led outputs right?
So ms has available output from,
- 2 iac
- 6 mid output from ms3x
- 2 inj from main board
-1 f idle
Am I thinking right?
So I don't have output for on/off output, fan and shift lights. But I can run the engine.
For v12 engines the header on ms3x pk7 and pm2 are used, right?
Can you make them available? With them I have all output that I want.
- 2 iac
-1 f idle
Re: BMW S62B50
There are not plans to open up those two V12 pins as general purpose outputs. It does sound like you have just got enough I/O for this monster VANOS install.
I believe the TIP125 could drive the VANOS, but I've not wired one up myself.
Re: BMW S62B50
Effectively the same as S54 from the look of it.ragepower wrote:AbatelliCristian: these are mine cam decoder
Re: BMW S62B50
I've implemented the four pairs of VVT outputs now.
Re: BMW S62B50
Great
I was thinking use the output these way:
- idle valve => inj bank 1, inj bank 2
- vanos valves => ms3x mid output and iac 1, iac 2
- vanos oil pressure accumulator valve => f idle
These way I don't need to modify the main board, besides the tip125 I just need to add a transistor to drive the tip125 on iac output.
Any disadvantage on this?
For more output only with a CAN board from Jpgref (don't remember the correct spelling), right ?
Re: BMW S62B50
@ragepower: what is the electrical resistance of the valves? That way you can estimate the pure static power consumption. I think a flyback circuit would be required. Other than that a tip125 should be sufficient.
Re: BMW S62B50
I measured 4 ohm, note that there is a diode on vanos unit. I switched the multimeter tips and measure the same.thokes82 wrote:@ragepower: what is the electrical resistance of the valves? That way you can estimate the pure static power consumption. I think a flyback circuit would be required. Other than that a tip125 should be sufficient.
Since they are high-side controled, it is necessary a flyback circuit? Or is a flyback diode enough?
Re: BMW S62B50
I think it depends on how BMW controls it. If the stock waveforms are just square wave (likely) diodes should do it.ragepower wrote:I measured 4 ohm, note that there is a diode on vanos unit. I switched the multimeter tips and measure the same.thokes82 wrote:@ragepower: what is the electrical resistance of the valves? That way you can estimate the pure static power consumption. I think a flyback circuit would be required. Other than that a tip125 should be sufficient.
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
Re: BMW S62B50
13.2V/4Ohm
=3.3A
You could start with a diode as it is not high frequency and control is just by slow bit-banging...
=3.3A
Re: BMW S62B50
From what I've read before and is posted above - the VANOS unit already has the diode built in.thokes82 wrote:13.2V/4Ohm
=3.3A
Re: BMW S62B50
Here you can see the inside of vanos unit. It may help. I had measured the same solenoid, both ways, and the result as the same. 4ohm.
If there is a diode, the measure should me diferrent, or am I wrong?
Re: BMW S62B50
I see four diodes !
See also Mario's post in the other VANOS topic.
Re: BMW S62B50
Ok.
About the transitor to drive the tip125 on IAC output. A BC337 or a 2N3904 is enough?
