MS3 now. MS3x later
MS3 now. MS3x later
Hello newbie here. I have a question if you can install MS3 /wo expansion now, and later put in the expansion in the box without any damage to both the mainboard and TunerStudioMS will flip out in anyway?
Re: MS3 now. MS3x later
thats fine just install the ms3x card and then change the settings to match as required, example if you use the main board injectors then switch over to the ms3x ones just change the setting in tunerstudio to match.
Alright thats nice, thanks for the answer
