SD Card logs in .MS3 format
I tried using an SD Card in the MS3 ecu, when I insert the card in the laptop to view the datalogs, they're in the .MS3 format and I can't view them in Mega Log Viewer;
I tried changing them to .msl , but the log fields are empty;
I tried changing the settings in TunerStudio... Nothing works
Re: SD Card logs in .MS3 format
Please read the manuals.
The Browse/Import SD Card function stays always blanked in TSjsmcortina wrote:Please read the manuals.
If I open the "Convert Binary Log" option, I get this error message Graph Panel Not Initialized
Please attach your MSQ.
jsmcortina wrote:Please attach your MSQ.
Is your laptop connected to a powered up ecu when you check the sd card function?dochka wrote: The Browse/Import SD Card function stays always blanked in TS
Cobra replica with 383 Chevy, ITB's, MS3X and LS2 coil near plugs
No, I unmount the card from the ecu and put it in the SD card slot in the laptop offline, then try to load the datacobratone wrote:Is your laptop connected to a powered up ecu when you check the sd card function?dochka wrote: The Browse/Import SD Card function stays always blanked in TS
I don't understand why that would be greyed out. I've done exactly that to process SDcard datalogs at the track this weekend just gone.
I've moved this topic to the TunerStudio sub-forum, perhaps they can offer some insight.
If you remove the card from the ECU, then "Browse / Import log will be disabled as that option is for TunerStudio to read the log files from the ECU.dochka wrote: No, I unmount the card from the ecu and put it in the SD card slot in the laptop offline, then try to load the data
What version TunerStudio are you using?dochka wrote: The Browse/Import SD Card function stays always blanked in TS
When do you get this error, as soon as you click it or after it says it is done?
I'm using version 2.9.120LT401Vette wrote:If you remove the card from the ECU, then "Browse / Import log will be disabled as that option is for TunerStudio to read the log files from the ECU.dochka wrote: No, I unmount the card from the ecu and put it in the SD card slot in the laptop offline, then try to load the data
I get the error after the conversion bar status starts
Even if I open the "Graphing & Logging" tab by itself, it stays in the initializing state forever
I think that is related to an issue I just fixed since 120, there should be an update later today or tomorrow.
In the mean time the converted log file should be there, it is just failing to open it in the internal Log Viewer.
