can egt 8 channel box
can i use this box to record two o2 sensors and two egt sensors at the same time on my ms3
Re: can egt 8 channel box
Yes, although the O2 sensors will need to be using Innovate controllers if you are running them through the CAN-EGT.
What is the serial patch cable for the LC-1? Does it come in the box with the LC-1 or is it something separate?
*edit* I found the patch cable 3812, since I have multiple LC-1's, can I make this cable by cutting up one of the Serial cables?
"Hey, at least the Skylark proves that even a messy hack can patch together a reliable EFI system. I can't think of a time the MegaSquirt has left me stranded since installation ~100,000 miles ago."
Drag Week 2011, 2012 & 2015. - BB N/A - 1977 Skylark w/Buick 455 EFI and TKO-600!
I believe they're just straight through, pin to pin.
You can use a simple audio male-male extension cable.
can you please explain the procedure for wiring them, i will be using the innovate o2 sensors with controllersMatt Cramer wrote:Yes, although the O2 sensors will need to be using Innovate controllers if you are running them through the CAN-EGT.
Which Innovate controllers do you have?
LC-2racingmini_mtl wrote:Which Innovate controllers do you have?
This was discussed here: http://www.msextra.com/forums/viewtopic ... 89#p467689. The LC-2 manual explains how to daisy chain multiple devices using the IN and OUT connectors.
