EAE tuning
EAE tuning
Can someone point me to a good explanation on this subject.
I've been trying to tune my AE and decel but seem to run into a problem with wall fuel interfering with certain things and leading to either lean issues on accel or severe popping on decel.
thanks
thanks
Re: EAE tuning
nobody can help with this ?
Re: EAE tuning
Have you read the manual?
Re: EAE tuning
I've read pretty much everything I can (manual, every forum post that popped up on google) regarding EAE tuning and spent two weeks messing with it every day and got pretty much nowhere, even went out for a tuning drive one night and hit a d*** deer for my effort. No matter how I played with the curves I couldn't keep the AFRs even remotely flat, always lean on accel and rich on decel, not to mention the it kept leaning me out to the point of missing/popping at low vacuum/low boost. Gave up and went back to Accel Pump AE.
95 Dakota, 5.2, 5 speed, 4x2, HX40, 12PSI, MS3X, 42lb Bosch Design 3 Injectors, AEM UEGO.
Re: EAE tuning
A comment like :muythaibxr wrote:Have you read the manual?
This curve determines how much fuel is being sucked from the walls on each intake (valve open) event. It is a
percentage (Y-axis) of the total amount of fuel that has adhered to the walls based on load (X-axis), so therefore
the percentages are much smaller (about 10x smaller) than the Adhere-to-walls coefficients.
Doesn't mean a thing other than explaining in general terms what the curve is about. There is no information on the tuning process itself, unless I have missed a part.
Re: EAE tuning
Please let the rest of us know if you do find anything.
I'm really struggling to get accel pump working well enough, so would like to try EAE.
With the info available though, just go in blindly with trial-and-error seems like it would almost be impossible to get right.
Re: EAE tuning
X2MWPau wrote:Please let the rest of us know if you do find anything.
Re: EAE tuning
Re: EAE tuning
Thanks Matt
Re: EAE tuning
That link was from the manual by the way.
Re: EAE tuning
Apparently the DIY MS3 pro manual. I don't have a pro. In the manual I have for TS there is nothing about it written besides the more general description like quoted.
Re: EAE tuning
The exact same thing is in the MS3 manual. See section 4.15 :
http://www.msextra.com/doc/pdf/html/Meg ... p-1.4.html
The TS manual doesn't covers the "Tuning" part. It's mostly talking about "which button to press to do the specified action". You will need to read all 3 manuals as said here :
http://www.msextra.com/manuals/ms3manuals/
to have a complete understanding on the whole MS3 thing.
Have a good day!
Sam
Have a good day!
Sam
