I will soon be setting up meth injection with an SSR. I want to connect SW12V to the pump and use Nitrous1 to pulse the negative side. Can someone please confirm that my crude drawing below is correct.
I am assuming that since my output will be Nitrous1, I can test this in Test Mode by pulsing PP4-Nitrous1.
Thanks.
PWM With SSR For Water Injection Question
Scottie
Turbo LS Volvo 244
8.746 @ 154.94
Turbo LS Volvo 244
8.746 @ 154.94
Re: PWM With SSR For Water Injection Question
Looks correct to me, as long as the nitrous control is ground from ms
Thanks, Nathan. The plan is to use Nitrous1.
Scottie
Turbo LS Volvo 244
8.746 @ 154.94
Turbo LS Volvo 244
8.746 @ 154.94
For those running a similar setup, what kind of DC% are you finding you have to run to get the desired volume? Pic of your table with some details would be great.
Scottie
Turbo LS Volvo 244
8.746 @ 154.94
Turbo LS Volvo 244
8.746 @ 154.94
