I've noticed that if Boost Control is OFF but Overboost Protection is ON, Boost Control Settings is not greyed out under the Boost/VVT tab. Does this mean that Overboost Protection is still in effect?
Scottie
Turbo LS Volvo 244
8.746 @ 154.94
Turbo LS Volvo 244
8.746 @ 154.94
Re: Overboost Protection
That's the way I'm using it, for protection only and it works.
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
You could test that by lowering the overboost value and seeing if it activates.
1967 Mustang Coupe, 351w, S475 turbo, MS3.0 3x, c4, 8.8, ls coils, e85
