Hello everyone. I have read the Mega manual a few times over but I'm still a little bit confused on where the missing tooth is relative to TDC. I have few ideas but would like to verify them.
1. Can the missing tooth be any place on the crank so long as when at TDC the sensor and the #1 tooth are 50deg(6cylinder)?
2. The manual always shows the sensor on the left side of the crank. How does 50deg work if i need to mount the sensor on the right side?
Trigger wheel missing tooth location
Re: Trigger wheel missing tooth location
50 deg is a recommendation, not a solid rule.redfogo wrote:Hello everyone. I have read the Mega manual a few times over but I'm still a little bit confused on where the missing tooth is relative to TDC. I have few ideas but would like to verify them.
Not sure what you mean here.2. The manual always shows the sensor on the left side of the crank. How does 50deg work if i need to mount the sensor on the right side?
Place the crank sensor anywhere that is convenient. It is the phasing between the trigger wheel and the crank sensor that matters.
And, abandon the obsolete Megamanual; use the manuals linked-to at the top of this page
Yeah sorry I thought the current manuals were also called mega manuals. I meant the most current manuals are what I had been reading. Thanks everyone I Understand what I was missing now
