Cost and Area Reduction
I don't know who is designing the hardware for the MS3X board but here's a way to reduce circuit cost and component size. Rather than dissipating the reactive energy (of the injectors) in each injector driver transistor, we can use a single clamping circuit for all eight. This lowers the cost for each of the drivers as they will no longer be dissipating the reactive energy. I also added a capacitor to the clamping voltage rail. This capacitor will lower the ground spikes by maintaining a steady flow to ground and should result in a quieter ground. See the attached PDF.
1979 Camaro
383 stroker w/Ramjet EFI manifold
MS2 Extra running semi-sequential, wasted spark
Re: Cost and Area Reduction
Mmmm, he said quieter ground.. SOLD.. hehe. Bring on the V4 mainboard.
Brian
'84 Dodge Rampage
'84 Dodge Rampage
The MS3X has already been laid out and the first prototypes are in a production queue. The output uses one VND5N07 per channel, the same as the Sequencer and Microsquirt.
How are the heat sinked?
1979 Camaro
Reflow soldered to the board, no external heatsinking.
So long as Jean publishes instructions for using his P&H board with the MS3, I'll be happy.. I love that board.
Brian
'84 Dodge Rampage
'84 Dodge Rampage
You can be sure that there will be a way to use the P&H box externally.
I hope that there are now two grounds (power and signal). It would be nice to have a seperate ground return (to the block) for the injector MOSFETs. My SBChevy setup with the MSII has been plagued with ground noise. Please say it is.
1979 Camaro
Are they isolated from the other ground? I assume that these are MOSFET source grounds only. Is that correct?
1979 Camaro
Well? Does anyone know if the power ground and signal ground have been isolated? They really should!
1979 Camaro
