I've done a search and seen the two upgrade posts and read the upgrade doc but I'd like opinions on weather I should hold off until MSIII comes out or start with MSII and upgrade to the MSIII board when it's available. I'm not trying to be the "is it done yet?" kid in the back seat.
My primary reason for waiting for MSIII is ignition control with COP. In fact, that's a huge part of why I want to go to MS in the first place. I know I can cobble it together with Ignition drivers and a pair of EDIS drivers but I'd rather use what seems like a more complete system in MSIII. However, I could simply switch to an EDIS non COP system on MSII for now if the upgrade path is not so massive, or if MSIII is a long way out on testing.
Additionally I'd be very happy to contribute to testing, and I have read that DIYautotune is getting some MSIII beta boards in place. I have a BMW M10 just itching for EFI.
Ok so basically the question is wait for MSIII or start with MSII and upgrade when the kinks are worked out. I don't mind kinks, it's not my primary car, but it does run as is so I am not necessarily in a hurry.
Thanks,
Milo
Upgrade path from MSI to MSII to MSIII
Re: Upgrade path from MSI to MSII to MSIII
I *think* one question that may be pertinent to your decision would be whether your intended coils have their own ignitors in them or not? If they don't, then you probably may as well start building, since you'll need to build in the high current coil drivers. (the electronic geniuses on here will hopefully correct me if I'm wrong about that)
On the other hand though, you'll need to build at least a secondary input circuit for a cam input that you won't have to build if you wait for the MS3 release. . . Unless you want to run wasted spark with your COPs for now. . . ? I think I shouldn't have tried to answer this question.
On a four or six cylinder, you can run COP with the existing MS2/Extra, or even MS1/Extra code. It will need a cam sensor and a crank sensor to do this, no matter what processor you go with (unless you go with a missing tooth cam wheel, although that won't be as accurate).
Ok, I need to read the manual more. Thanks!Matt Cramer wrote:On a four or six cylinder, you can run COP with the existing MS2/Extra, or even MS1/Extra code. It will need a cam sensor and a crank sensor to do this, no matter what processor you go with (unless you go with a missing tooth cam wheel, although that won't be as accurate).
This is helpful, I specifically don't want to run wasted spark.Tjabo wrote: On the other hand though, you'll need to build at least a secondary input circuit for a cam input that you won't have to build if you wait for the MS3 release. . . Unless you want to run wasted spark with your COPs for now. . . ? I think I shouldn't have tried to answer this question.
scratch that, found out I can upgrade to a ms3 from a ms1 v3.0.
Scratched. . .
Yep, that's exactly what I did. I had to make my msq mostly by hand but the imported fuel/spark tables made tuning go very quickly.jabran200 wrote:scratch that, found out I can upgrade to a ms3 from a ms1 v3.0.
